bizhub c250 code c2555
  • repeatcopiers
    • Sep 2008
    • 591
    Can someone tell me what this code is? Don't have color models in my Intravia and can't find similar code listed under B/W models. Thanks
  • rocky246
    • Feb 2007
    • 91
    Abnormally low toner density detected Yellow TCR sensor. May need to replace yellow imaging unit.
    • ukyo
      • Aug 2008
      • 51
      C2555: Abnormally low toner density detected Yellow TCR Sensor
      Relevant Electrical Parts:
      IU-Cyan
      IU-Magenta
      IU-Yellow
      Toner Supply Motor C/K (M6)
      Toner Supply Motor Y/M (M7)
      Mechanical Control Board (PWB-M)
      MFP Control Board (PWB-MFP)
      Solution:
      1. Peform image troubleshooting procedure if image density is low.
      2. Clean the TCR Sensor window on the underside of the IU if dirty.
      3. M6, M7 operation.
      4. Reinstall IU.
      5. Change IU.
      6. Change PWB-M.
      7. change PWB-MFP
      • redime
        Check the obvious... make sure your toner is getting into the IU
        Run toner auto supply a few times, print half tone patterns (122 density) in tech rep mode and see if you have a solid yellow pattern on a full 11x17 sheet, if not, replace your yellow IU
        • B0265
          • Jan 2007
          • 718
          First of all, check that the shutter mechanism on the toner cartridge is working and that the film that is attached to the shutter isn't broken and blocking the entrance of the cartridge.
          • mitchl
            • Apr 2007
            • 501
            Theres a bulletin out on this and we are seeing it constantly!
            get me an email address and Ill forward it along.
            • repeatcopiers
              • Sep 2008
              • 591
              repeatcopiers@tx.rr.com Thanks so much!!
              • mitchl
                • Apr 2007
                • 501
                Check your email my brother!
                • Haroldbfix
                  • 212
                  I agree and make sure the IU drive gears are not hard to turn form the customer storing the IU in a vertical position and all the developer and toner compacts to one end of the IU
                  • ni311
                    • May 2008
                    • 658
                    Maybe you're lucky and all you have to do is change the toner bottle wit a new one. If the user is trying to get the most of the toner bottle he'll end up with this type of code, depending on the color.
                    Konica Minolta Error Codes - Explanations and Solutions
                    • DadO
                      • Dec 2007
                      • 401
                      Mich, if u could send me an bulletin on my e-mail dado.copy@gmail.com i would BE GRATEFUL since i cant loog in for last 3 days on infohub (bad username error .....lol).
                      I have same error code on C 252 machine
                      • mitchl
                        • Apr 2007
                        • 501
                        Good to go, check your email!
                        • nmilisic
                          • Mar 2009
                          • 30
                          Please if you can send me that bulletin, I have c2555 on c250p.
                          Thanks! nmilisic@t-com.me
                          • olo
                            Could I have one also? PM a link if you can.
                            • tarzak911
                              • 55
                              yellow image unit....check tcr sensor../ check toner supply or toner release tab..
