Error Code C-6756 in ineo +454e
  • Guest
    hello ,
    the machine takes a long time to start
    then after it starts i get this error c-6756
    i choose continue to ignore the error it says that the original scan function will be deactivated
    so i have to switch off and on the sub-power
    when i switch it on nothing happens just black screen ... it seems that error can't be ignored
    - i isolated the scan in service mode the machine freezes at first start
    - i noticed that i couldn't hear any sound of the motors moving that i hear normally when i start it nothing moves at all ,
    have you ever experienced this error ?
    this is what i found in service manual :
    i appreciate any suggestion on this ,
    thank you very much
  • copier tech
    • 8174
    Re: Error Code C-6756 in ineo +454e
    There was a tech bulletin regarding trapped wires in the scanner unit, around the CCD area, the metal cable clamp was too tight. You might ant to check that.
    • Guest
      thank you for replying i will take a look to that
      do you think that could prevent all the motors from starting ?
      • Guest
        i checked it and it seemed normal no trapped wires
        thank you very much for your advice,
        what i will do next is to remove the CCD board (CCDB), Scanner drive board (SCDB) and DC power supply (DCPU) from an other machine and try them on this one , hope i will find the faulty board
        • Guest
          hello ,
          update :
          i checked all the wires and changed all the boards and still the same error c-6756 ,
          i noticed after switching on the power button the printer doesn't make the smallest sound just scary silence
          NO fan is turning and NO motor is moving !
          have anybody ever experienced that or have any idea how to solve it ?
          any suggestions are very much appreciated , thank you
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            hello ,
            update :
            I'd be pulling out the volt meter at this point and checking all outputs from the dc power supply are actually present. 5v rail to mfp board is all thats needed for mfp board and panel to start in deathly silence.
            • Guest
              hello,
              thank you for your suggestion , i said that i changed the power supply board with other one from other machine so the problem is not in the board itself , so you are saying that the wires relating DC power supply board with the other boards maybe faulty ?
              i tried to follow every rail to its destination in the machine and in the wiring diagram but i just could to test one or two rails !
              for example 17 2-Q , 14 24-I , 15 24-L how can i find this in the other board and what board ?
              thank you for any suggestions or advices
              • habik
                • 2013
                hello,
                [ATTACH=CONFIG]34474[/ATTACH]
                Have you tried replacing or bypassing the CIS and CCD cable?
                What voltage are you getting from power supply:
                When all connected and which pin what voltage:
                CN-004
                1
                2
                3
                4
                5
                6
                7
                CN-005
                1
                2
                3
                4
                5
                6
                7
                CN-006
                1
                2
                3
                4
                5
                6
                7
                8
                CN-007
                1
                2
                3
                4
                5
                6
                CN-008
                1
                2
                3
                4
                5
                6
                7
                8
                9
                CN-009
                1
                2
                3
                4
                5
                6
                7
                8
                9
                10
                11
                12
                CN-010
                1
                2
                3
                4
                5
                6
                Firmwares HERE
                • mx6turbo89
                  • Oct 2013
                  • 154
                  Here's another thing to try that might help:
                  Error
                  Abort code CF907 and/or error code C6756.
                  Failed ErP board (PWB-DC assembly)
                  Check CN2 on ERPB for proper connection. Check CN2-1 and CN2-2 for 5V DC then check CN2-3 (Power monitor in) and CN2-4 (Power monitor out). If all voltages are present, replace the ERPB (p/n A161H00C02).
                  • Guest
                    CN-004
                    i will bring the machine to our workshop test all this
                    Error
                    thank you
                    i replaced ERPB same problem
                    i will test the voltage when i bring it to the workshop
                    • Trigger
                      • Aug 2014
                      • 16
                      Id take this back to basics.... try a trouble reset function to see if the display will come to life and if it does UNSET the scanner again. First rule is if it was working before you changed something then you caused the fault.
                      If the machine does not boot i advise going through the troubleshooting guide for the no boot SSD problems TNEU1400013EN. It also notes in here a C-6756 code issue, which states to do a system error clear.
                      • Guest
                        the only one that i get voltage from is CN006
                        CN006
                        2-3-4 GRD
                        5 5V
                        6 5V
                        7 5V
                        i did the same test on other printer the seame result came out that the CN006 is only one that i get voltage from
                        did i miss something or is there an other way to test other pins
                        thank you very much
                        • Guest
                          hello ,
                          update :
                          i replaced the mfp board and the ssd board from an other machine and the machine started with fans and motors and everything
                          so i assumed that i have to change the MFP board for this machine
                          then i put its old MFPB back and weirdly starts (motors & fans were not making any sound at first )
                          now the machine starts but i get this error and i'm not able to remove it : C- E301
                          anybody have any idea about this C- E301 ?
                          thank you
                          • tech51
                            • 846
                            In my experience e301 has always been a corrupt print job. Is it connected to a network?
                            • habik
                              • 2013
                              hello ,
                              update :
                              thank you
                              What firmware have you flashed it with?
                              What machine and type have you set when you were replacing the MFPB? and what have you got now during FW loading procedure?
                              Firmwares HERE
