Error Code C-6756 in ineo +454e
  • allan
    RTFM!!
    • 5459
    #31
    Re: Error Code C-6756 in ineo +454e
    Originally posted by Synthohol
    allan, do you need firmware?
    Thanks. I have the firmware.
    Whatever
    • allan
      RTFM!!
      • 5459
      #32
      Its Alive
      Needed one more restart its working!!
      One of the breads here decided its a good idea to strip of the CCD chip ....
      Whatever
      • allan
        RTFM!!
        • 5459
        #33
        Its back.
        The reset works to clears the problem but its back....
        I did replace the MFPB then its worked fine for a while...
        Where could this problem hide.
        I know its not the PSU or the dual scan bord or the MFPB.
        Time will fix it but its frustrating to wait a week for a result every time i make a change.
        It even happen if the machine just sits and do nothing.
        Any body got the fix for this?
        Whatever
        • allan
          RTFM!!
          • 5459
          #34
          Found the SSD trouble shooting guide.
          Seems like the SSD is the guilty one.
          Can i swop the SSD from a C284e to the C454e and then use the Reset tool?
          Whatever
          • Synthohol
            Certified Konica Expert
            • 5740
            #35
            If you want to roll the dice on that I'd change the machine type on the ssd first then install on other machine and wipe it.
            There was some bulletin about "temporarily" testing an ssd in another machine but the machine type programmed must be the same.
            Hell I'd risk it. My motto is "drive fast and take chances"
            Good luck.
            • allan
              RTFM!!
              • 5459
              #36
              So i changed the SSD with a new one and did the Firmware.
              Worked for a day and then....
              Its back again.
              Have now changed every thing except the OACB.
              including all relevant and irrelevant parts. Power supply, CCD, dual scan board...
              Why after a board reset it works for a while.
              Changed MFPB and it woks for a while.
              Same with the SSD format and replacement works for a while.
              Why can't i disable the scanner when it asks if it wants to continue operation.
              Press on continue operation then it asks to switch the soft power on and off. It will switch off but not back on again...
              Thinking the factory data is truly corrupt and i cant get it overwritten???
              Whatever
              • allan
                RTFM!!
                • 5459
                #37
                ...It was the CCD data transfer cable...
                Whatever
                • allan
                  RTFM!!
                  • 5459
                  #38
                  I will just continue with this monologue.
                  Worked for 8 days....
                  chewing on my socks!
                  I refuse to give up bu it seems there is nothing left to do???
                  Whatever
                  • ttdsp
                    • Jul 2015
                    • 5
                    #39
                    Originally posted by mx6turbo89
                    Here's the C754 Tool: Dropbox - A145FW.TAR
                    hi
                    can you please provide the a61ffw.tar
                    thank you
