KM C280 with MFP Board from C220 Trouble
  • fadsamniote
    • Apr 2016
    • 80
    Hello !
    I got a C280 with Broken MFP Board , soo I found a C220 MFP Board (The C220 MFPBoard its Diferent from C280/C360) , and placed the NVRAM from C280 and its giving me Code offcourse.
    I tried to put C220 firmware but when I tried to update firmware It wont show MFPBoard.
    What can I do to put the machine working ?
  • Elmo
    • Feb 2010
    • 541
    Re: KM C280 with MFP Board from C220 Trouble
    Use the correct MFP Board
    C220 MFP will Not Work with C280/C360
    I Used To Live To Fix Things Now i Fix Things To Live
      • 14723
      Perhaps a C280 MFP board would solve this.
      • fadsamniote
        • Apr 2016
        • 80
        I dont have C280 Parts , I only have C220 parts , If I change the Printer Controller of the c280 to a C220 should work ?
        Because I check all PART NUMBERs of the C220/C280/C360 and the Only think that change its the MFP Board.
        • emujo
          • Jun 2009
          • 3009
          What part of "It won't work" do you not understand? The boards are different part numbers. If I remember there are connectors that are not present on the C220 board, what are you gonna do, just leave cable harnesses disconnected? Emujo
          • fadsamniote
            • Apr 2016
            • 80
            I know the Part Number its Different !
            The MFP Board use the same board connectors , I checked because I have the 2 machines.
            I think I only must change the firmware because the rest of the Boards in the machine its same as c220/c280/c360 because Part Numbers its the same , but I dont how to put the machine working.
            • Woxner
              • Jul 2011
              • 848
              i will say it too. IT WONK WORK>>>>>> the firmware is also written on the prcb.
              • jotunn
                • 617
                Bizhub C220 machine as a MFPB donor for C280/C360 is pretty useless - you can use almost all the other parts, but MFPB is unique for C220.
                Main differences between boards:
                - crystal oscillator 54.3MHz (c280/360), 36.2MHz (c220) - used as a clock signal for PH unit
                - resistors under nvram:
                * C280/360 - R1085 jumper / R544 102 1k / R543 empty
                * C220 - R1085 empty / R544 empty / R543 472 4.7k
                - group of resistors on the right side of memory connectors sign. "A"
                * C280/360 - R315 472 4.7k / R316 empty
                * C220 - R315 empty / R316 472 4.7k
                Belive me, I have tried... The best result I could get, was working machine - but every printed image was 1/3 larger than normal.
                • Albonline
                  • Sep 2008
                  • 1150
                  if memory serves me, there are 3 id chips hidden throuhout the copier, that tell it what it is
