bizhub 200 touch screen adjustment
  • brent
    • Nov 2008
    • 1212
    I cant seem to find this adjustment.. racking my brain thought I would ask here
    thanks all
    the reason I need this is because when we input fax numbers or letters it goes to the letter next to the intended one
    hoping the touch screen adj will work thanks
    brent
  • allan
    RTFM!!
    • 5462
    Re: bizhub 200 touch screen adjustment
    I have not done this in ages i think its a little like a B250 when it comes to that.
    Find the reset button on the back of the machine hidden behind a little cover press that to get the reset screen and the screen adjustment.
    I could be dead wrong.
    Not sure if you have to press "3" on the restart.
    Whatever
    • brent
      • Nov 2008
      • 1212
      I remember that button.. it seems like in the set up on these machines this was one thing that was done.. its been too long ago
      I will look at the set up instructions thanks for the help
      brent
      • darry1322
        • Oct 2010
        • 817
        Try Stop-0-0-stop-0-2
        • brent
          • Nov 2008
          • 1212
          thanks everyone. I finally found it in the maintenance mode. Screen. It fixed the problem
          • CraigW
            • Dec 2010
            • 417
            Hope it sticks..... those displays all fail sooner or later.
            • mascan42
              • Oct 2008
              • 484
              Is there any way to get to this without touching "end" after the 0's? The top half of the screen is unresponsive even after replacing the touch panel.
              • Nicoabd
                • Jun 2020
                • 2
                • tsbservice
                  Field tech
                  • 8016
                  Maybe with some trials you can guess/hit where to touch display instead of [END].
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4702
                    It's not that the screen needs adjustment or calibration. Those touch screens going bad was one of the most common problems on that series. You can get the aftermarket touch screen for around $50 USD.
                    • JR2ALTA
                      • Feb 2010
                      • 2033
                      I agree replacement of the screen is ultimately unavoidable but just a tip to run a thin ID card under & around the perimeter for any gunk.
                      • copyman
                        Owner / Technician
                        • Sep 2005
                        • 4702
                        JR2 suggestion is worth a try. Problem with OEM touch screen was the foil pattern lifting off board from heat. Back when I was working on these I must of replaced at least 50 of these touch screens. Once replaced with aftermarket never had to replace again. It was a poor designed OEM part. This was one case where the aftermarket was better than OEM !! And less expensive, Think the OEM touch screen was around $200 back then.
                        • mascan42
                          • Oct 2008
                          • 484
                          This is what I wound up doing. Just by pure luck I got it, but it took like five minutes of poking around on the screen.
                            • 23008
                            Funny story:
                            I had a billable customer that used his bizhub 200 only for printing, so when it had an error message (sorry, can't remember which) this customer expected me to install a new control panel only long enough to reset the error, then put that new panel back on my shelf at no charge. I found this request quite funny. =^..^=
                            • tsbservice
                              Field tech
                              • 8016
                              Funny story:
                              Funny indeed but I will call this person quite impudent
