pro c754 error s1 & s2
  • ash_572
    • Oct 2008
    • 523
    i have a konica pro c754 with a message on the command workstation giving me an error s1 and s2.
    everything seems to be working perfectly fine.
    i have cleaned the optics even though it was clean anyway.
    the manual states ccd and cis gain adjustment failure.
    i reset the message in service mode under warnings and a week later the message re occurs.
    any help would be appreciated.
    thanks
  • habik
    • 2013
    Re: pro c754 error s1 & s2
    What firmware level have you got loaded at the moment?
    Firmwares HERE
    • ash_572
      • Oct 2008
      • 523
      I have no idea sir,
      could it be the firmware?
      • Albonline
        • Sep 2008
        • 1153
        thanks
        the message is saying something wrong with scanner in the adf, not the main ccd, try looking up in there . also in trouble reset mode do the aes adjustment after you clean everything. if it returns after that you will need to trouble shoot/replace, the adf interface cable.have seen a couple that turned out to be the dual scan board on the main body or the ribbon cable that attaches it to the mfp board.
