Set UP SMB to Public Folder on PC - Bizhub C550
  • bungapads
    • May 2009
    • 69
    I need some assistance. Does anyone have complete instructions on how to set up my C550 such that when I scan a document to a PDF file I can get it over to my computer? I have some direct scans to PDF in user boxes, but I need to be able to get those PDF scans and move them to my computer so I can use them in Adobe Reader, etc. Thanks
  • mx6turbo89
    • Oct 2013
    • 154
    Re: Set UP SMB to Public Folder on PC - Bizhub C550
    Here's setup instructions from KM: https://www.dropbox.com/s/8gggme2awn...SMBv4.pdf?dl=0
    • Woxner
      • Jul 2011
      • 853
      make a folder and share it with everyone. put the folder on the root drive. then just do a new registration use the host or ip of you computer file path is folder name. its case sensitive, user name and password your done. also under you network make sure the file sharing is on
      • allan
        RTFM!!
        • 5462
        You could use FTP utility it nothing else works.
        Got to love the SMB server function on the new machines where you can use a BOX as a shared folder on the network.
        Easiest way by far when it comes to teaching the users to setup new users all by them selves.
        Whatever
        • copier tech
          • 8200
          Or you can also set up a gmail account, then simply program the relevant settings into your bizhub this will enable you to scan your documents as a PDF to your inbox.
          See this video below, you may need to turn your monitor upside down to view
          • allan
            RTFM!!
            • 5462
            Type machine into your browsers address bar.
            You can download the scans in your user box from PageScope Web Connection.
            Look for the box tab.
            Whatever
            • peter42
              • Jan 2012
              • 110
              SMB scan from MFP to PC at a non Domain controlled Network.
              Login at PC.
              create a local user named "scan" with password "scan"
              dissalow him to change password.
              create a new folder on your HD
              name it scan.
              free this folder for network for user "scan" with write permission.
              go to MFP
              create a new SMB scan program
              IP adress or Hostname of PC, look at the button, Hostname used
              directory is "scan"
              user is "scan"
              Password is "scan"
              if that works, you can change user, password at your or owners will.
              first the basics, than the security.
              greetings peter
