Biz 601 ADF strange problem
  • copyman
    Owner / Technician
    • Sep 2005
    • 4653
    ADF will jam, machine will stop, jam indicated at ADF top door. Weird thing is ADF continues to run until you turn machine off and back on. Also there is always paper jammed under the white platen on bottom of ADF.
    I didn't have time to look at it today, I was there to service 2 other machines. Just gave it a quick look, blew out sensors and it still did it. It is intermittent but happen 2 times when I was there.
    Anyone ever see this? Figured I would throw it on the forum before heading back out.
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: Biz 601 ADF strange problem
    It happened to me when I replaced the rollers and accidentally pinned the detect sensor behind the feed ass'y
      • 23002
      Jam code? =^..^=
      • copyman
        Owner / Technician
        • Sep 2005
        • 4653
        This the jam code was 66-01
        • allan
          RTFM!!
          • 5462
          Happen the very first time with me. Easy to miss that.
          Whatever
          • JR2ALTA
            • Feb 2010
            • 2033
            Not to be lost, my point was if the adf is continuously running it think it has paper so you should be able to focus in on the detect sensor/actuator
            • copyman
              Owner / Technician
              • Sep 2005
              • 4653
              Thanks JR2, after I left account I was thinking it was probably the sensor getting hung up. First thing I will check when I go back. What threw me off was ADF motor continued to run even with adf lifted or top door open. What ever happen to "safety" interlock switch, ha-ha. Jap's are usually overkill with the interlock crap.
              Will post what I find.
              Thanks again to everyone that replied
              • EarthKmTech
                Step aside, noob
                • May 2009
                • 2139
                I've had the motor for the pre-read rollers spin in the wrong direction intermittently and it was the ADF control board. That was pretty obvious though.
