BH-363, "Thick2" not fusing well
  • Hansoon
    • Sep 2007
    • 3391
  • habik
    • 2013
    Re: BH-363, "Thick2" not fusing well
    Is it peeling off or smudging?
    Byting on bits.
    Firmwares HERE
    • mo0651
      • 1054
      yes!!! it's called THICK 3 !!!
      • Hansoon
        • Sep 2007
        • 3391
        Smudging & offsetting. Toner can be rubbed off too.
        No!!! it's not a color but a mono machine having only maximum THICK 2!!!
        Hans
        • minimerlin
          • 851
          Are the fuser rollers OEM?
          Grad adjustment done?
          Please do not PM me without asking first.
          • allan
            RTFM!!
            • 5462
            Jip does not work well at all on that machine.
            It does not even transfers properly on the thicker stuff.
            Add a resistor inline on the thermistor lead.
            Who does not like a nice fire?
            Whatever
            • Hansoon
              • Sep 2007
              • 3391
              UFR is of our own production which is proven to be by FAR outstanding OEM.
              Grad adjustment has been done since set up about 40K ago, but I cannot see the connection between that and the bad fusing. Even when reducing the density in the service mode problem exists though a little less.
              Thanks for thinking with me guys.
              Hans
              • allan
                RTFM!!
                • 5462
                Also like the 3de party ones better.
                The 3de Party thermistors works like magic, does not scratch like the original part.
                Whatever
                • mo0651
                  • 1054
                  Looking at the Thick settings, Thick to specs should work. Is it glossy paper?? are you sure of the GSM rating?
                  • Synthohol
                    Certified Konica Expert
                    • 5855
                    from a technical standpoint, if the paper brand is not listed in this attachment its not supported unless you send Konica a couple reams to test and officially approve it with the suggested settings or they can say it wont work and thats not your problem...technically.
                      • 14868
                      On this series you can change "User paper settings" to adjust the thickness. It allows thick setting higher than Thick 2. I think it is in service mode, or it could be in admin mode.
