Bizhub C-25, 4FFF code...
  • Oystercopy
    • Oct 2009
    • 623
    This happened to my (own) machine at home, right when AT&T was "repairing" my network. Can anyone tell me, is this RE-settable? or is the only option replacement of boards?
    Thanks in advance,
    OC
  • Paskudny
    • Nov 2020
    • 2
    Re: Bizhub C-25, 4FFF code...
    And how did you solve the problem? I have the same..
    • Oystercopy
      • Oct 2009
      • 623
      I never did, I just trashed the machine...
      • Synthohol
        Certified Konica Expert
        • Mar 2016
        • 5808
        4FFF: Controller connect error
        18.4.30
        18.4.31
        C002: RAM error at startup (standard memory)
        C003: RAM error at startup (expanded memory)
        Relevant electrical parts
        MFP board/1 (MFPB/1) MFP board/2 (MFPB/2)
        Step Action WIRING DIAGRAM
        Control signal Location (electri
        cal component)
        1 Turn OFF and ON the power switch. - -
        2 Check the MFPB/1 connector for proper
        connection and correct as necessary.
        3 Check the MFPB/2 connector for proper
        4 Check for proper connection between
        MFPB/1 and MFPB/2 and correct as nec
        essary.
        5 Change MFPB/2. - -
        6 Change MFPB/1. -
        best advice is to trash it.
        thats coming from someone that still owns an analog EP2030.
        • tsbservice
          Field tech
          • 7990
          You know of course analog machine is way simple and sometimes reliable than fancy-schmancy new ones. If you have working consumables why not 😄
          • copytechman
            • Nov 2008
            • 931
            18.4.30
            18.4.31
            cal component)
            essary.
            6 Change MFPB/1. -
            EP2030? Wow that brings back memories... EP450Z, 470Z, 1030, 1031F, and so on and so on!
            Regards!
            A.
