Scan to file on Bizhub C350
  • tip32a
    • Sep 2025
    I have inherited a Bizhub C350 with firmware dated 2004-09-06. I only need it as a copier/scanner NOT printer. I have been successful at getting FTP to work but after 6 or 7 batches I have to wait almost an hour for it to process and send the job and allow me to restart scanning. I want to attempt SMB but there's is no place in the setup to enter the username and password of the shared folders on the PC. I am using windows 10. If I absolutely have to I can use an XP machine but there are many reasons why I would like not to do that.
    Do I need an updated firmware? Am I out of luck?
    Any help would be greatly appreciated.
    Tom
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2059
    Re: Scan to file on Bizhub C350
    There is a softswitch in service mode that needs to be set to allow username and password for smb scanning.
    • Synthohol
      Certified Konica Expert
      • 5961
      from Konica's knowledgebase. KBA00901468
      Question
      How to use host name instead of TCP/IP address when setting scanning.
      Answer
      The bizhub C350 does not support scan to SMB it supports scan to FTP. When entering the FTP server information the TCP/IP address of the FTP server must be used.
      i have used Kyocera's FTP program with a konica. strangely it works.
      also its really easy to setup FTP in XP Pro. better than some app from the interwebs.
      from the manual specs...
      > Scan to FTP with URL Notification
      Scan to PC with URL Notification
      Scan to E-Mail
      Scan to HDD with URL Notification
      TWAIN
      Scan to IFAX
      Data to be transmitted
      Resolution: 200 200
      Color Mode: Monochrome
      Compression method: MH
      • techandtrader
        • Jun 2016
        • 336
        I know just a little about this on one machine I ran into and a desire to smb scan at an office.
        I found out a few things.
        1. I read that there was a special firmware released and that maybe the firmware that enabled SMB scanning. ( take with big grain of salt! )
        2. We were successfully able to SMB scan on a C450 and at the time the date on the machine or firmware was 2006.
        I dont work on these, just very rare occasion have had to deal with them in the past. Since we are talking about 2004 your only hope on the lower grade c350 most likely is FTP.
        I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
        • Synthohol
          • 5961
          i searched the KB for SMB on the C350 and if there is special FW i wish it would have come up in the search. i hate giving false advice.
          • Woxner
            • Jul 2011
            • 855
            the c450 could do smb but the c350 could not. i know of no special firmware for the c350
            • habik
              • 2013
              Crush it!
              Firmwares HERE
              • tip32a
                Crush it??? Care to elaborate? Is it going to explode like my Samsung phone? It appears to be a workhorse and it scans like lightning.
                • tip32a
                  I cannot find it in my docs. Do you have more detail?
                  • IT Sup
                    From my understanding SMB is starting to use version 3 which is causing a lot of issues on different brands. Instead of SMB, I'd use FTP and isolate the folder in question (don't put on root). I've used FTP for older machines (I've had good luck with Quick 'n Easy FTP Server Lite). It limits to 3 users, but only need one. Hope that helps or points you in the right direction.
                    • EarthKmTech
                      Step aside, noob
                      • May 2009
                      • 2139
                      You could try twain scanning if the c350 supports it and let the computer do the processing instead of the obsolete C350 hardware.
                      • peter42
                        • Jan 2012
                        • 110
                        For these old machines i use "personal ftp"
                        Its also an easy way, to solve smb trouble with w8 and w10.
                        Google for it, if you find "michael roth" software, you are on the right way.
                        Its very simple to set up after installation.
                        • Lokertr
                          • Nov 2016
                          • 12
                          I am trying to set up the scan to FTP on this machine, but the controller will not save any settings I enter in the pagescope web connection page for the one touch buttons...it wont even save them for the temporary registration. I click create after entering the information and it just bounces back to the list of indexes.
                          I am not sure what I could be doing wrong...
