Bizhub C452 black image issue
  • konica7022
    • Nov 2008
    • 132
    hi bizhub c452 suddenly started printing like this, some one suggested that its is not getting black toner
    i check toner is enough and tried to pour some in the drum manually but still get the same result94D4E0A7.jpg after cleaning i get this white lines at the top as well
    ALSO in need a rebuild instructions for Color IU for bizhub c452 if any one can help
    • 23003
    Re: Bizhub C452 black image issue
    If this was a sky shot, your developer is dead. Start with a DV612K black developing unit. =^..^=
    • konica7022
      • Nov 2008
      • 132
      it has 40% life left how can it all of a sudden die? :/
        • 23003
        Are you going to let that yield indicator dictate when you will solve this quality issue? You will probably never get to 0% remaining. The images will go completely blank, or give Add Toner indications long before you get to 0% remaining. This might be one of those opportunities for you to think for yourself. =^..^=
        • allan
          RTFM!!
          • 5462
          Charge issue?
          Is that a sky shot or a print?
          Whatever
          • konica7022
            • Nov 2008
            • 132
            Originally posted by allan
            Charge issue?
            its a sky shot(more like a ceiling shot)
            ok blackcat4866 i will swap the dev unit and post again
            What about the Color IU rebuild instructions?
            • konica7022
              • Nov 2008
              • 132
              ok changed the DEV, its working fine now
              but the black print is coming Tooooooo Dark?
              also some times the machine gives the error c 2258
              i checked all the waste toner motor connections and greased all the gears but the error still comes some times
                • 23003
                Did you clean anything? Did you do a stabilization and gradation? The manual covers this nicely. =^..^=
                • konica7022
                  • Nov 2008
                  • 132
                  yes i did gradation only wanted to do stabilization but got busy, will do that today machine is printing fine
                  except for following error
                  error c2558 apears some time, could this be the reason the Dev unit got damaged?
                  • EarthKmTech
                    Step aside, noob
                    • May 2009
                    • 2139
                    was that a new developing unit you installed or a second hand one ?
                    tcr sensor calibration is only performed on a new unit.
                    • konica7022
                      • Nov 2008
                      • 132
                      it was old one, swapped it from another machine, after few prints it gives me c 2558 error like 2/3 times a day
                      what i read in the manual TCR calibration is done every time you open and close the Front Door
                      • allan
                        RTFM!!
                        • 5462
                        No TCR is only initialized once by reading(popping) the new chip. TCR is monitored constantly.
                        If you are a ninja you can fix it by adding or removing toner.
                        Every TCR sensor is a little different(tolerance) that is why new developer is factory mixed to exactly 6.5%.
                        Whatever
                        • konica7022
                          • Nov 2008
                          • 132
                          Nailed IT
                          The developer i used swapped was from C452 into C552 machine, Since it was old so timing/speed difference with the toner Gave me error Code C 2558
                          which is now fixed i as put the Orignal DV unit back into C552 and poured the Developer of C452 in to DV unite of C552
                          All works fine, but after 3-4 days use the black ink starts to fade away again
                          i intalled new black toner, but still no use, filltered and added more developer(used one) works for 3 days and Fades away again!
                          • copier tech
                            • 8136
                            You have answered your own question, Fit A NEW developer unit & stop messing around topping up old units, you have no way of knowing how much to pour in!
                            A new dev unit will run way past 500k if the machine is looked after.
                            I have had a couple of failed PRCB boards fail not driving the toner supply motor.
                            A0P0H00102 PWB Assenbly (PWB-MC ASSY)
                            • konica7022
                              • Nov 2008
                              • 132
                              I manually added the toner to the DV and it is working totally fine, which means it is the toner motor issue or the board
                              how shell i test the motor to make sure its motor not the board?
