Hello All,
I am working on a Bizhub 361 that has an issue I have seen once before but never got to fix.
It is a scanning issue in that the internal prints and PC Prints are fine but anything that uses the scanner ie Faxing or Copying the scanned image is bad. If you scan from the glass the image is 3/4 solid black with the rest being mostly black with a few fine lines. If you use the document feeder the scanned page is almost all BLANK with a few fine lines. I have checked the interface cable to the CCD but that does not help. It does seem to change a little bit? But it does not correct the issue. I have tried reseating the cable 4 or 5 times.
Since I personally have seen this on 2 Bizhub 361/421/501 machines I am assuming some of you have seen / corrected this issue.
Thanks!
Thanks!
