edge of paper doesnt print on ineo 454
  • jakani
    • Dec 2014
    • 147
    hello,
    first i know it was a drum problem but it took me some time to change it a month or more then when i had the chance to change it same problem one edge doesn't print out so i thought the faulty
    drum affected the transfer belt today i changed the transfer belt did a gradation adjust but still the same !
    now the only thing i have in hand is changing the fusing unite ,
    but i thought on asking your opinion on this
    thank you very much
    here i attached the counter samples to compare scan.pdf
  • tech51
    • 846
    Re: edge of paper doesnt print on ineo 454
    There is no image on your scans. Suggest you do them again.
    • CraigW
      • Dec 2010
      • 417
      When you click on "document properties" it states "page size" is 7.95" x 8.16"
      That is what I would look into myself.
      • Woxner
        • Jul 2011
        • 841
        i see some fading. clean your laser
        • mo0651
          • 1054
          we have had bad printheads replaced on this series.
          • jakani
            • Dec 2014
            • 147
            Re: edge of paper doesnt print on ineo 454e
            it is a pdf file , you can click on scan.pdf to view it
            no it's the right page size it happens even when i print the counter
            i changed the drum recently , what laser should i clean could you tell me more
            Thank you all for your suggestions i really appreciate it
            i don't think we are talking about the same printer
