Help needed Bizhub 950
  • hotfuser
    • 180
    Please can someone help me.
    I am having trouble loading firmware onto a new board (image process and OACB)
    The ISWTrns tool will not let me install through USB.
    I seem to remember that there needs to be an USB driver loaded on PC before sending firmware through ISWTrns.
    This is not happening. All info would be much appreciated.
  • Synthohol
    Certified Konica Expert
    • 5735
    Re: Help needed Bizhub 950
    I thought the connector was an let cable under the plate to the right side of the scanner glass.
    It's been a while though.
    Did you tell is you want to use USB instead of lpt? In one of the menus.
      • 22930
      I don't remember what it looks like, but the connector you're looking for is on the print card, under a black sticker. I seem to recall it being a USB connection, and I do seem to recall a print driver being installed. It took several attempts of re-booting the MFP, then the laptop, to get the two to communicate. =^..^=
      • Synthohol
        • 5735
        hope this helps.
