Bizhub 751 Network Interface Problem
  • Naveed Shahid
    • May 2008
    • 162
    [Misc] Bizhub 751 Network Interface Problem
    Hello Every One
    I installled network interface chip on bizhub 751 but machine still not access to network print
    any idea
    thanks
  • peter42
    • Jan 2012
    • 110
    Re: Bizhub 751 Network Interface Problem
    how do you install network interface chip?
    thats a completly new procedure to me.
    • allan
      RTFM!!
      • 5462
      More info.
      Do you get the network option under admin?
      Have you initialized the network settings?
      Found a couple a machines where the network tab would be missing before initialization.
      Whatever
        • 23009
        Does this help?:
        Or you could read the instructions in the package. =^..^=
        • allan
          RTFM!!
          • 5462
          Hehe. Never done that before. Never needed to...
          You made me read it.
          Whatever
          • peter42
            • Jan 2012
            • 110
            As far, as i remeber, there was a long time ago bulletin from minolta:
            The notch at the chip was in opposite direction of the installation mark.
            That ruins a lot of chips and boards also.
            Cant imagine, this was coming again....
            • emujo
              • Jun 2009
              • 3009
              Network settings are available regardless of the print enabler (chip) as the 751 scans out of the box, it's the printer settings that won't pop up before the chip is installed. There are 2 slots, one is marked "SC" this is the security chip slot and should not be used for the print IC. There is nothing to turn on the if chip is working and installed properly. My guess is a bad chip..This should be an IC-208 for the 751. Even after installing one upside down once, it still worked when reversed and installed correctly. Emujo
              • CopierNerd
                • Feb 2015
                • 207
                Incorrect installation can be a reason. Check it again.
