bIZHUB 423 TRAY 1
  • jonpaul
    • Jul 2014
    • 59
    bIZHUB 423 TRAY 1
    Now will not print one piece of paper from tray 1. The paper jams as it starts to exit from the fuser.Changed the loop adjustment,new firmware.Jam code now 99-01 controller jam.Tray 2 and bypass still working.No other messages about paper size.at a loss.
  • CraigW
    • Dec 2010
    • 417
    Re: bIZHUB 423 TRAY 1
    What is total counter ?
    If 300k + the registration bushings would be suspect.
    • Synthohol
      Certified Konica Expert
      • 5846
      Was tray 1 feed unit replaced from another model?
      The 423 has an extra sensor that the slower models don't and can give the symptom you describe.
      • Mr Spock
        Vulcan Inventor of Death
        • Aug 2006
        • 2064
        9901 can also be mis-sized paper. Make sure paper size and orientation is correct for tray 1
        • Synthohol
          • 5846
          Yeah thats a symptom too, it jams and says blah blah paper size in the tray.
          The extra sensor in the 423 is for paper length and without it the paper is seen as a different size and asks to load paper size correctly.
          Good luck, let us know!!
          • Albonline
            • Sep 2008
            • 1151
            Have seen more than a few 363 and 423 do this because the drive motor slowed down, try trading the two on the back around.
            • antone
              • Oct 2014
              • 344
              What's the fix 9901 all trays
              Sent from my SM-N920V using Tapatalk
              • Albonline
                • Sep 2008
                • 1151
                replace the drive motor.
                • Albonline
                  • Sep 2008
                  • 1151
                  check the registration rollers for tightness, should roll with very little resistance.
