bizhub Press C1060L Fit-to-Printable area problem!
  • CopierNerd
    • Feb 2015
    • 194
    [Misc] bizhub Press C1060L Fit-to-Printable area problem!
    Hi,
    I want to print A5 job on A4 paper. For this i have tried every option available but when the print comes out, one side is not printed about 4 to 6 mm area. I have tried scaling up to 130 to 140 %, Fit-to-printable area, full bleed, custom settings every option but the print is incomplete. one side is mis-printed. It can be any side up, down, left or right.
    I have also tried this on different machines but the result is same. Any suggestion or advice from any expert would be helpful and appreciated! ???
    waiting
    kind regards,
    Copier Nerd
  • Synthohol
    Certified Konica Expert
    • 5737
    Re: bizhub Press C1060L Fit-to-Printable area problem!
    Is it a pdf?
    Maybe try printing to PDF with the paper size you want to save it as or convert the job to the paper size you want if you can?
    • CopierNerd
      • Feb 2015
      • 194
      The job is in PDF. I do not want to resize the original job according to the output size. I do not want to edit the job. I want that machine fit the job according ot the paper size, when i have selected "fit" option in printing preferences menu.
      • Synthohol
        • 5737
        does it have a Fiery?
        have you tried a different driver or application to print it from?
        Foxit reader does a splendid job of printing things adobe finds difficult if you want to try another safe PDF app.
