Hecon connector kit
  • mascan42
    • Oct 2008
    • 481
    Hecon connector kit
    I have a customer who had a Hecon remote counter hooked up to their old copier, and the connector was taken away with the old machine (the pickup drivers say they didn't take anything, of course). The connector kit supplied by Konica only has the part that goes from the 4-pin black connector on the copier to a large 6-pin white connector. The Hecon cable left behind at the customer's location is a smaller 6pin connector. There's supposed to be a short cable that goes in between that has a ground wire coming out of it. Where do we get this from?
  • Synthohol
    Certified Konica Expert
    • 5799
    Re: Hecon connector kit
    what model do they have now?
    • mascan42
      • Oct 2008
      • 481
      They had a C452 and the new one is a C454e.
        • 22997
        Many of the older copiers had a loop that completed the key counter circuit. the C454e will have 4 wires that lead to a male and female connector, but no wire loop. It's enabled in Manual Function Choice (page I553 of you service manual).
        According to the C452 service manual there is a 7 wire harness that leads to an 8 pin connector, but no loop. Look at page 721 of your field service manual: Management Function Choice.
        Nope. No wire loop. =^..^=
        • leprosydog777
          • Jan 2018
          • 33
          Hello all i have a bizhub c558 i connected a hecon counter all is working but customer wants to turn on authentication for scans but lookin at the machine when you enable management function and turn on key counter authentication in admin mode is not available. Can some one help me to have admin authentication be available even with management function is used please
