BizHub C224 on Deep Sleep
  • joaopauloooo
    • 46
    I have a BizHub C224 with a strange issue, when it goes to low power or sleep mode it doesn't come back, it stays sleeping until I switch the power off and on again.
    I tried everything to wake up the machine, touched the whole screen, every button and nothing happens.
    I can't even print anything because it goes offline. But as soon as switch off and on again it works great and prints everything.
    Another thing, hen it is awake and I press the sleep button it goes to sleep and if I press it again it comes back normally.
    When I formatted the HDD the problem went away for a day, but then It came back.
    Is there any configuration that I'm missing, what should I do?
    The machine is from 2013 and has only 33k prints.
  • habik
    • 2013
    Re: BizHub C224 on Deep Sleep
    Print listoutput from service mode and tell us what firmware level is the machine this moment.
    It is a chance you have old SSD firmware and is starting to fail causing issues you experiencing.. Be carefull as it might go all the way and replacement of ssd or mfpb will be required.
    Latest ssd is ver 6.05m
    There is certain precautions that have been described on forum before. Search is your best friend.
    Or post more info so we can start from there a.e firmware level..
    Sent from my iDon't believe in marketing device using Tapatalk
    Firmwares HERE
      • 15055
      It was the "e" series with the flakey SSD boards. The non "e" had an issue with sleep mode. I seem to remember a setting in Admin mode. Something like enabling power usage in sleep mode. And it is never a bad idea to update firmware.
      • habik
        • 2013
        A bummer didn't notice.. Thanks for pointing it out.
        Firmwares HERE
        • wseyller
          • Sep 2012
          • 1129
          I would go into service mode and permit the option to turn off sleep.
          Go into admin mode and turn off sleep. It will still go into low power mode, which you cannot turn that off.
          set the enter power save mode from immediate to normal.
          set power consumption in sleep mode to disabled.
          • CopierNerd
            • Feb 2015
            • 207
            You should update its firmware or initialize the machine.
            • REGSIS
              • May 2016
              • 440
              Update FW to latest version and in addition to above turn off weekly timer which automatically turn off machine on specified time.
              I experienced this on e models also, and other models too.
              • CopierNerd
                • Feb 2015
                • 207
                Increasing the sleep mode time can also be an option to try!
                • joaopauloooo
                  • 46
                  • Gaffers01
                    • May 2011
                    • 336
                    There is a tech buletin for your issue,
                    Solution:
                    Adjust the following settings:
                    [Admin Mode] > [System Setting] > "Power Supply / Power Save Settings" :
                    1) On page 1 - Touch "Enter Power Save Mode" - and select "Normal"
                    2) On page 2 - Touch "Power Consumption in Sleep Mode" - and select "Disabled"
                    • copier tech
                      • 8235
                      Definitely update the firmware, a good tech will do this every visit as part of their service, this is good practice on all manufactures models.
                      • joaopauloooo
                        • 46
                        When I try to update the firmware it only shows the options to update the ADF, Scanner and Printer. It's not showing MFP Controller.
                        I have tried the "A1610Y0-F000-G20-68-100-CHECKSUM-BBB7" and "A1610Y0-F000-G20-72-100-CHECKSUM-dbb4"
                          • 15055
                          Unless you have the LK-101 (web browser) installed on this machine, you have to use G00-72 firmware, not G20-72.
                          • joaopauloooo
                            • 46
                            Well, I updated the firmware but the problem persists. Guess I'm now out of options.
