Bizhub C203 Firmware
  • TechMayday
    • Nov 2016
    • 9
    I bought a used bizhub C203 and upon startup, it is stuck at the hourglass. I replaced the Ram and no change. I'd like to try reloading the firmware. I think the latest is:C203 GRG-R6 C203_A02E0Y0-F000-GRG-R6.exeI'm not a dealer... help?
  • ivovb
    • 695
    Re: Bizhub C203 Firmware
    I prefer mass production version A02E0Y0-F000-G20-R6. Anyway this hourglass might be HDD, PCB... Try trouble reset procedure before any expensive repair.
    BR
    I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
    • shadow038
      • Jun 2015
      • 10
      If firmware does not work, try memory chip.
      • TechMayday
        • Nov 2016
        • 9
        Turns out that the memory I used was defective. Now I am able to start the printer but it sticks on error C-D010. Hard drive unformatted. The touch screen locks up and I am not able to enter the service mode to format it?
        Help?
        • copier tech
          • 8196
          Have you tried reflashing the firmware?
          • scottybbb
            • Dec 2010
            • 126
            Try unhooking the hard drive and you should be able to get into service mode.
            • TechMayday
              • Nov 2016
              • 9
              I bought this firmware: A02E0Y0-F000-GZ1-R6 I'm using a SanDisk 256 MB CF card, I wrote the firmware using The Konica Minolta Firmware Imaging Toolkit 2_53. I Tried disconnecting the hard drive and the printer never finished starting, stuck on Konica Minolta Logo. I appreciate any ideas / help
              • TechMayday
                • Nov 2016
                • 9
                I tried the reset procedure and it stops at the KM logo as well.
                • mx6turbo89
                  • Oct 2013
                  • 154
                  Sounds like you've got an NVRAM problem.
                  Here's the NVRAM Clear firmware: https://www.dropbox.com/s/8y9mgbk2wb...00%29.EXE?dl=0
                  Here's the procedure (Read this first before starting): https://www.dropbox.com/s/7xpg17b9q4...hames.pdf?dl=0
                  • TechMayday
                    • Nov 2016
                    • 9
                    Huge thanks, making progress... I was able to follow your instructions and reset the NVRAM, now it says: "serial number needs to be entered" "Contact service representative" - dont have a rep...
                    The instructions say to enter service mode either I am doing something wrong, or ?
                    I press Utility Counter key and it beeps, I press stop and it beeps, then i press 00 stop 01 and each time it beeps but the screen does not advance.
                    • Synthohol
                      Certified Konica Expert
                      • 5879
                      hold down utility when booting for service mode
                      • TechMayday
                        • Nov 2016
                        • 9
                        Holding utility down during boot hangs on planets screen.
                        Swapped out main board, flashed firmware A02E0Y0-F000-GZ1-R6
                        and still hanging on "serial number needs to be entered" "Contact service representative"
                        • ivovb
                          • 695
                          Stop-0-0-stop-0-1 press them in same intervals of time and don't wait for beeps.
                          BR
                          • TechMayday
                            • Nov 2016
                            • 9
                            Still not working?
                            Any other ideas?
                            BR
                            • ivovb
                              • 695
                              Wait for warning beeps to stop (initialization is finished) and than start with U/C-S-0-0-S-0-1.
                              BR
