Konica Minolta Bizhub C552
  • wellconnected
    • Oct 2010
    • 23
    [Misc] Konica Minolta Bizhub C552
    I have C552 that will not display the scan screen.
    It copies and prints ok but when scan button is pressed nothing happens.
    this machine was just relocated by customer to another site.
    Anyone come across this before?
    Theory is when you know all and nothing works. Practice is when all works and nobody knows why. In this case we have put together theory and practice: nothing works... and nobody knows why! (Albert Einstein)
  • allan
    RTFM!!
    • 5462
    Re: Konica Minolta Bizhub C552
    Determine if the HDD is there and working.
    Whatever
      • 23010
      Make sure that the HDD is Set in service mode. How it becomes UnSet? I don't know, but it does. =^..^=
      • allan
        RTFM!!
        • 5462
        I am one of the causes. The HDD on these machines go bad and if its a copier only it ends up disabled and life goes on.
        Whatever
        • RRodgers
          • Jun 2009
          • 1947
          I've seen a firmware update unset it. Stopped scanning after I did firmware.
          • karim-tech
            • 47
            hi
            check HDD
            service == system 2 == HDD == INSTALLED
