biz hub 658
  • serviceman678
    • Sep 2016
    • 19
    biz hub 658
    brand new out of the box the machine will start to cycle then it will lock up konica had us change the fuser first off then the fuser drive continued with the same problem the they had us change the mfp board because the fuser stoped applying pressure now we get a code of 3101 or 3103 has anyone seen this it started right out of the box with this issue and no there isn't any packing material in it still. Any help will be highly appreciated
  • Synthohol
    Certified Konica Expert
    • 5808
    Re: biz hub 658
    on previous models the fuser AND the IUs used the same ICP chip on the board. i wonder if they still do?
    even though the code was for the fuser, we finally changed all 4 IUs and no more fuser codes. totally mind-blown.
    hope yours is not so elusive.
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      Re: biz hub 658
      bet its snagged wiring shorting to the chassis or rubbing on a motor
      • ncbabak
        • Apr 2014
        • 43
        • Albonline
          • Sep 2008
          • 1147
          Re: biz hub 658
          on the related connectors, reseat the wires into the saddles, to ensure contact between conductors and connector pins.
