Lost the trifold option on my C360
  • Snufsis
    • May 2015
    • 6
    I have a Bizhub C360 With a SD-509 that I bought used and when I started it recently the tri-fold option under finishing was no longer there. The only folding option that exists is half fold and that works fine with and without stitches. I can't chose trifold on the control panel, neither from my PC. I have checked the contacts between the finisher and the copier. What may have happened?.
    • 23010
    Re: Lost the trifold option on my C360
    In that option Set or UnSet in the service mode? =^..^=
    • kingarthur
      • 1399
      looking at the product guide for FS527 & FS529 for the C360, trifold, nor Z fold is available....
      • emujo
        • Jun 2009
        • 3009
        You can't have saddle stitching w/o trifold, but the MFP can detect trouble with the tri-fold and isolate it, and it can be manually isolated in service mode. What I mean is at some point the tri-fold system probably had a problem. When this happens the control panel displays a message about the trouble and asks if you want to continue without it. The operator says yes (cycles the sub power switch) and the device re boots without tri fold options. This is available for many of the non critical features. Normally a power cycle will start the whole isolation process over again. If it has been turned off in service mode, then it will stay that way until "unset". I don't believe there are any options to prohibit tri-fold operations so it probably is related to fault isolation. Emujo
        • Snufsis
          • May 2015
          • 6
          Thanks for your reply, I will check that but can not recall that Trifold had a set/unset in rhe Service Mode.
          • Snufsis
            • May 2015
            • 6
            Thanks for your reply!
            All options are UnSet in the service mode.
            Best Regards
            Sven
            • Snufsis
              • May 2015
              • 6
              Thanks for your most interesting reflection! When I got the C360 a couple of days ago I powered it up having A4-papers in the LCT-tray. I then had the tri-(or Z-) fold option on its display using it as a copier. After getting the load A4R in the manual tray message, the option was all gone. I've been through the system settings and verified that folding is not "isolated" or disabled in any way. What would be the working accessories to get tri- and/or Z-folding on the C360?
              • Snufsis
                • May 2015
                • 6
                Hi Emujo and thanks for your kind reply!
                I have gone through all visible settings in the service mode. I can't recall any error message about a problem with folding and question about continuing without it. I have checked everything selectable to be in UnSet mode and not isolated. Are you sure that the FS-527 and SD-509 will be a working combination for tri- or Z-fold? Another friend here suggests that it may not be the case.
                Best Regards
                Sven
                • kingarthur
                  • 1399
                  This is from the C360 product guide
                  Installation
                  Functionality FS-527 FS-529 JS-505
                  Maintenance
                  Non-Sort/Sort/Group yes yes yes
                  Spare Parts
                  Shift Yes (30 mm) Yes (30 mm) Yes (30 mm)
                  Recommended
                  Media
                  Corner Staple yes yes no
                  Appendix
                  2 Point Centre Staple yes yes no
                  Saddle Stitch yes, with SD-509 no no
                  Punch yes, with PK-517 no no
                  Half Fold yes, with SD-509 no no
                  Tri-Fold no no no
                  Z-Fold no no no
                  Max. Paper Capacity 3000 sheets (A4) 300 sheets (A4) 150 sheets (A$)
                  Max. Staple Capacity 50 sheets 50 sheets ---
                  • emujo
                    • Jun 2009
                    • 3009
                    The C360 CAN saddle stitch and fold with the optional SD installed. It can only fold with plain paper, but even with thick paper in all trays the option should be present, just a message on the control panel advising not available unless plain paper is selected. If you can cycle power and not get the SD isolation message, and it's not unset in service mode, then you must have a failure in the connection to the finisher control board, or a power supply issue (although I doubt that only the SD would be affected in this scenario). Take a look in service mode and see if the SD shows up in the firmware listing. Emujo
                      • 15068
                      I just looked up features of the SD-509 and tri-fold isn't one of them. Saddle stitch and half fold only. Hope this helps.
                      • kingarthur
                        • 1399
                        • emujo
                          • Jun 2009
                          • 3009
                          C360_SD.pdf
                          OK this is from the User Guide..and I installed the C360 driver...1/2 fold is available, but not tri fold. Very surprising to me as I thought tri-fold was available. So the original poster must be wrong in his thread that he had trifold available, then didn't. Emujo
                          • Snufsis
                            • May 2015
                            • 6
                            I e-mailed the question about C360's ability to make tri- or Z-folds to KonicaMinoltas Service Desk and they replied that SD-509 will make trifold but not Z-fold. I also remember that I had a series of paper stops before the tri-fold option disappeared. The paper stops was caused by a plate at the inlet of the finisher that had got a little bent during transportation but that was an easy fix. Please note that half-fold works great, its just tri-fold thats gone. What about doing a factory reset of the C360?
                              • 15068
                              Tri-fold became available on the 4 series, but was never available on the C360 series. Check out a brochure and you will see.
