BizHub 223
  • copyman
    Owner / Technician
    • Sep 2005
    • 4718
    BizHub 223
    This account is a good distance from my shop and wanted to get some insight before heading out. The customer said drawer 1 doesn't close right and they have to shut really hard for it to stay closed & for it to work. When they close it regular it sticks out a little so they have to push really hard.
    I told them to take paper out of drawer 1 and only use 2. They called back and said when they receive a fax it keeps telling them to put paper in drawer 1. Which brings me to my next question, where is the setting to change what drawer faxes feed from? Or at least what manual it is in. I looked through a few of the user manuals and didn't see anything. Without being in front of the machine it is hard to remember some of the settings that aren't used much.
    Thanks in advance
  • copier tech
    • 8169
    Re: BizHub 223
    Most likely is there is paper trapped behind tray 1 stopping it from closing correctly, or the paper trays/latch can break they are only plastic.
    You can change the paper try options using the utility/counter button scroll through the options you will find it.
    • Rvale
      • 83
      Re: BizHub 223
      you can fid it on the service manual, age 195 is the easyest way to sort it out.
        • 14791
        Re: BizHub 223
        On the feed assembly there is a lever that drops the pick-up roller. Where that lever contacts the paper tray develops a burr and makes it difficult to close the tray. Smooth that area with a piece of emery cloth or fine sand paper. That will make the tray easier to close.
