konica Minolta BIZHUB 751 not printing more than one copy at a time
  • gavrielx
    • Oct 2015
    • 57
    Hi,
    I have a weird problem recently in one of my clients.
    Printer not printing more than one copy at a time i try in Word and Acrobat?
    Windwos 7 32 bit.
    BizHub 751 Last Driver.
    Any suggestions?
    tanks
  • methogod
    • Dec 2008
    • 917
    Re: konica Minolta BIZHUB 751 not printing more than one copy at a time
    what if you print a blank word document?
    copy is ok?
    sounds like hard drive in print controler (but need more info)
    • Woxner
      • Jul 2011
      • 841
      does this happen in adf and on glass? if so clean the sensor under the drum. could also be the webb. when it reaches the limit it does this.ck the web counter and reset
      • gavrielx
        • Oct 2015
        • 57
        copy is ok?
        can't print a black word document.
        copy is fine.
          • 22999
          I would connect my laptop via crossover cable, and test printing that way. If it prints properly, you may just have a very poor network connection. At that point, I would plug my laptop into the network cable of the customers network and ping back to the server. Watch for long ping times (more than 5 ms), and dropouts. =^..^=
          • gavrielx
            • Oct 2015
            • 57
            the connection is just fine
