bizhub C3350 shows error code E301
  • Laserbeam
    • Aug 2011
    • 152
    [Error Code] bizhub C3350 shows error code E301
    bizhub C3350 shows error code E301 (error signal reception: referring incorrect memory)
    the service manual recommends: contact KM
    they said: format HDD or replace HDD, SSD, RAM
    Problem known? Has someone had this error?
  • Woxner
    • Jul 2011
    • 850
    Re: bizhub C3350 shows error code E301
    this can happen when using authentication but this may help
    Error
    C-E301
    Root Cause
    Firmware requires updating
    Workaround/Fix
    Install the following Firmware versions.
    • bizhub 4050/4750 firmware version A6F730GA804-W51
    • bizhub C3350/C3850/C3850FS firmware version A3GN30GA804-W51
    • tech51
      • 846
      Although e301 can be caused by many things, it's mostly corrupt print jobs that seem to cause it.
      I would update the firmware to the latest and then restart the machine with the network cable out.
      If it's ok as a copier, but codes up when you refit the cable, it will be a print job fault.
      • Albonline
        • Sep 2008
        • 1151
        [QUOTE=Laserbeam;547980]bizhub C3350 shows error code E301 (error signal reception: referring incorrect memory)
        try running it without the added 1gig ram.if it works well with it out , the firmware is the cause,install latest firmware without the ram think its 21 engine and 851 controller, flash engine before controller updates and reflash engine again. test without ram and then with it. if ok then good, if not ssd is next suspect, followed by mfp board. low power mode also will cause these to lockup and not wake when a print is sent to them. try setting to sleep before low power hits.
        • venluckey
          • 36
          Where can i get Firmware
          • bizhub C3350/C3850/C3850FS firmware version A3GN30GA804-W51\
          • Does some one have this file? I have a MFP we are trying to setup but keeps throwing this error.
          Error
          C-E301
          Root Cause
          Workaround/Fix
