C552 & C652 Dumping Developer on Rear Side
  • MFPs R Now PCs
    MFP Tech & I.T. Manager
    • Jul 2011
    • 156
    [Misc] C552 & C652 Dumping Developer on Rear Side
    We have some bizhub C552/DS & C652/DS machines dumping developer on the rear side. Sometimes when replacing the drum and sometimes not (randomly). We seem to have hit a wall with how to permanently remedy it as this is happening on multiple machines. I have attached a picture for reference. Thanks in advance!
    It does not matter how slowly you go as long as you do not stop. –Confucius
  • Synthohol
    Certified Konica Expert
    • 5941
    Re: C552 & C652 Dumping Developer on Rear Side
    make sure the machine is level, ive had a few that tilted back towards the wall do the same thing
    • copier tech
      • 8296
      This is a known issue. Make sure all the contacts the the drum dev, itb etc are all clean, its caused by a lack of bias charge etc.
      Can also be caused by a failed HV2 A0P0 M408 00
      • JR2ALTA
        • Feb 2010
        • 2033
        I think there's a bracket involve as well. I don't have KM access anymore. I think it's a bulletin
        • copier tech
          • 8296
          The bracket was for the previous model C451 I believe
          • DigiMan
            • Jan 2013
            • 262
            If i remember correctly the bracket applied to these machines as well,but the newly added drums had a mod on their own?I may be wrong though..
            In any case you could always try fitting a clip on the backside of the IU for it to not loose contact with the spring.
            I do recall having some pictures about this,if i find them i'l post.
            I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.
            • MFPs R Now PCs
              • Jul 2011
              • 156
              Thank you! If you find the pictures that would be great.
