"Fusing plug missing "
  • slytukana
    • Feb 2015
    • 48
    [Error Code] "Fusing plug missing "
    I try removing and fitting the riser but nothing change.
    Attach is what appears in the panel
    Thanks in advance for your assistance
    Sent from my HUAWEI RIO-L01 using Tapatalk
    • 22999
    Re: "Fusing plug missing "
    It might be pertinent to know what model that you're considering.
    But just on the most basic level, there isn't any power to one of the power plugs. Find out why. =^..^=
    • slytukana
      • Feb 2015
      • 48
      It's a Konica Minolta bizhub 654
      • Synthohol
        Certified Konica Expert
        • 5804
        i take it this is not a U.S. machine? there is only a single 20A plug on the U.S. models.
        • slytukana
          • Feb 2015
          • 48
          To be more specific it's a bizhub 654 .The machine has only done a 105 prints it was working well but as been not in use and switched off for some months and recently I try switching it on and it came up with the error "Fusing plug missing"
          • jrn821
            • Jan 2017
            • 2
            Hi, Has anyone solved this? Ran into same problem today. Cant find any Information regarding it. Thanks
            • dlandry
              • Sep 2015
              • 4
              I am having the same problem after doing an all clear for a c163. My take on it would be that the machine is confused and thinks its a model with a separate fuser plug.
              I figure a good place to start would be to set the correct time and time zone. This machine will only show tab number 8 Device information so not able to put correct time.
              what I ended up doing was turning off smart fusing control under system 2 in service mode.
              • jrn821
                • Jan 2017
                • 2
                Ran into this again. Latest firmware resolved
                • tsbservice
                  Field tech
                  • 7979
                  Why not replied into this thread if FW resolve but now?!?
                  • Walterj
                    KONICA MINOLTA
                    • Jun 2017
                    • 89
                    good day
                    Dears
                    The error mentioned usually happens when the NF1 board is damaged
                    It is possible to repair it you have to have some knowledge in electronics
                    Greetings
