Undo "Endless 90% Consumables" bizhub C452/552
  • MFPs R Now PCs
    MFP Tech & I.T. Manager
    • Jul 2011
    • 156
    We have Hex settings for the 3 soft switches to "turn on endless 90% consumables" on bizhub C452/552's. However we want to revert it back to the original settings so the machine will indicate "call for" new imaging units again and don't have those settings.
    Turn ON is:
    Switch 50
    Hex 01
    Switch 51
    Hex fo
    Switch 55
    Hex oc
    What are the settings to Revert/Turn OFF???
    Thanks in advance!
    It does not matter how slowly you go as long as you do not stop. –Confucius
  • copier tech
    • 8101
    • MFPs R Now PCs
      • Jul 2011
      • 156
      Re: Undo "Endless 90% Consumables" bizhub C452/552
      So just make all 3 soft switch HEX values 00 ?
      • copier tech
        • 8101
        Yes
        • MFPs R Now PCs
          • Jul 2011
          • 156
          Yes
          Thank you for the clarification!
          • Grebom
            • Oct 2012
            • 5
            Will the life stop affect scanning to email and faxing?
            • Synthohol
              Certified Konica Expert
              • 5737
              only when the machine locks out for the consumables.
              you can still set to no stop in IU stop and yes to the reminders so when the IUs go EOL they can just hit ok and use the machine, the reminder is persistent though.
              • afterhours
                • Mar 2017
                • 152
                This is correct.
                Im a Loser Baby!!!
