pinting problem on ineo +454e
  • jakani
    • Dec 2014
    • 147
    hello ,
    i have a problem when printing and copying i get a faded line in the middle of the paper
    i changed the drum , the transfer belt and the fusing unit
    i initialized the counter and did image stabilization still the same problem !
    here is a copy of the counter :
    any suggestion on how to solve this would be appreciated
    thank you very much
  • kingarthur
    • 1369
    Re: pinting problem on ineo +454e
    I can't open the attachment, but a faded line is normally the printhead needs cleaning
    • jakani
      • Dec 2014
      • 147
      thank you for replying
      i attached it again
      scalln.pdf
      i don't think this printer has a printhead !
      • kingarthur
        • 1369
        i attached it again
        [ATTACH]35366[/ATTACH]
        I would think it has! I'd get a trained engineer to look at it !!
        • jakani
          • Dec 2014
          • 147
          thank you for replying kingarthur
          i just searched the manual for the printhead i could not find it !
          thank you very much again , if i could not solve this may be i consult with an other company or something getting an engineer is not an option i don't know one !
            • 14813
            If you aren't going to take the advice seriously, why bother asking. kingarthur gave you very good advice (this machine indeed does have a printhead).
            • jakani
              • Dec 2014
              • 147
              of course i take his advice seriously and i really appreciate it
              • Woxner
                • Jul 2011
                • 851
                take that placstic wand and read the easy instructions on cleaning the laser glass. if its called a printhead or laser who gives a crap it does the same thing.....
                if that dont work look at the dev unit. its good for 590 k may have something in it
                • jakani
                  • Dec 2014
                  • 147
                  i was not able to find it at first because in the manual it called PH unit ,
                  i cleaned it and the printer worked as it should , thank you very much for fast replying to direct solution
                  • REGSIS
                    • May 2016
                    • 435
                    PH=printhead
                    Laser printhead, LED printhead, ink printhead; every printer (or MFP) has a printhead!
