B4050 trouble code FB45 (000.00)
  • K33B0
    • Aug 2025
    [Error Code] B4050 trouble code FB45 (000.00)
    Hi I got an konica minolta B4050 that gives an trouble code FB45 (000.00) everytime the client sends a scan to mail it pops up. Can anyone help please?
    Sent from my SM-N910C using Tapatalk
  • Woxner
    • Jul 2011
    • 850
    Re: B4050 trouble code FB45 (000.00)
    dont see this code in the book
    • K33B0
      Could it be maybe putting on the fax kit afterwards on the machines
      • Qball
        • Jun 2013
        • 127
        I'm getting this, too. Researching now. K33B0, were you able to make any breakthroughs on this?
        I'm having this on a C3350.
        A quick search in the C3350 service manual shows FB45 being 'Asahi ASIC error (higher layer driver) JPEG compressing circuit: miscellaneous error'.
        It's pointing toward the MFP board.
        • Synthohol
          Certified Konica Expert
          • 5846
          Problem
          Code FB-45
          Solution
          CAUSE:
          An error code FB-45 after scanning a document as a JPEG or TIFF file type.
          SOLUTION:
          Set the PDF/A default setting to OFF as follows:
          Press Utility Key -> Administrator Settings -> System Settings -> PDF/A default settings -> Set to [Off]
          Technical Notes
          This issue was resolved by base firmware A3GN30G0803-W99. Only use the solution if unable to update firmware.
          hope thats it. good luck!
          • Qball
            • Jun 2013
            • 127
            Originally posted by Synthohol
            Problem
            Code FB-45
            Solution
            CAUSE:
            SOLUTION:
            Technical Notes
            Thanks. That's exactly what I did. I updated firmware to W99. Thanks for the reply!
