C3350 vertical/horizontal lines when printing color
  • aybo
    • Jan 2017
    • 6
    [Misc] C3350 vertical/horizontal lines when printing color
    When printing color, I get vertical and horizontal lines. Attached is what came out, it is supposed to be an all red page.
  • mo0651
    • 1054
    Re: C3350 vertical/horizontal lines when printing color
    What have done to attempt to fix this?? How old are drums and supplies? Thought about cleaning?
    • aybo
      • Jan 2017
      • 6
      I have tried to clean it, but I am unsure what to clean.
      I pulled out the toners and drums to clean that area. If its a part that needs to be unscrewed, I have not tried that. I do not want to take it apart if I do not have to.
      I have not yet tried to replace the drums yet. I will need to order a new set. I would like to hold off on doing that, my company tries to save every dollar.
      • mo0651
        • 1054
        And how many copies on it???
        • Woxner
          • Jul 2011
          • 854
          if they are cheap run a single color. cyan magenta and yellow. then determine which is bad.
          • aybo
            • Jan 2017
            • 6
            There are:
            Total 44822
            Color 35479
            Black 9343
            I've printed each color on a full sheet. They end up with the same results. Horizontal/vertical lines and now there are also magenta and yellow spots that appear a few times in a line.
              • 23010
              Originally posted by aybo
              There are:
              Total 44822
              Color 35479
              Black 9343
              The verbal description is not that helpful. How about posting those images?
              Red is composed of magenta and yellow. Any areas that appear yellow are missing magenta. Any areas that appear magenta are missing yellow.
              • MFPTech
                • 486
                He is an end user, not a tech.
                Sent from my SGH-I337M using Tapatalk
                • mo0651
                  • 1054
                  Do you know the Life expectancy of the drums and PM parts on your machine? And are you using OEM supplies?
                  • aybo
                    • Jan 2017
                    • 6
                    They are oem parts. The machine says that there is 20% of the CYM and 0% of the K.
                    Other than the streaks, there is no problem printing.
                    Attached are the scans of the colors. SKM_C3350170201153500.pdfSKM_C3350170201153700.pdfSKM_C3350170201153800.pdf
                    • allan
                      RTFM!!
                      • 5462
                      The lines in the feed direction could be toner on the laser glass.
                      The lines in the cross direction looks like pitch lines meaning gears that is jittery on the drive.
                      Is the machine more noisy than it should be or can you feel a vibration if it runs?
                      Whatever
                      • aybo
                        • Jan 2017
                        • 6
                        Nothing out of the ordinary. As long as I've worked here (for a few months), it's been the same.
                        The lines have been happening for a while, or so I've been told, but I never noticed because I don't print colored pages.
                        • mo0651
                          • 1054
                          I see 2 lines common to all colors, and then on the cyan copy, spots of magenta and yellow. I wonder if you pull out the color drum you may see those lines. And I would
                          closely inspect the transfer belt.
                          • Konicatech
                            • Feb 2016
                            • 133
                            Check the transfer belt - these machines are well known for wrecking belts, i have changed loads of them even on machines that are rarely used.
                            • BluaboardTwice
                              • Jul 2017
                              • 11
                              I would also look at the fuser and transfer belt for wear and their life count. if all is well with that i would change K drum first and check for any improvement.
