KM Bizhub 222
  • 1stcavvet
    • Apr 2015
    • 231
    [CQ] KM Bizhub 222
    I installed all new developer unit, drum unit and new developer. Ran f8 and all looked outstanding blacks ,great fill. 3 weeks later I'm getting still sharp copies but with a lot of background grey. they look like copies on grey paper. any ideas, main charge ,dv bias, drum ground. like I said drum and DV units are new any ideas, toner density??? Help
  • Woxner
    • Jul 2011
    • 850
    Re: KM Bizhub 222
    did you clear the counters for drum and dev before you ran the f8?? if not reset counters turn machine off then on to make sure they cleared then run f8.
    • 1stcavvet
      • Apr 2015
      • 231
      Re: KM Bizhub 222
      Yes I cleared the counters before I pulled the old units out of the machine ran the f8 when reinstalled the new ones
      • BR549
        • 111
        Re: KM Bizhub 222
        Generic toner?
        • CraigW
          • Dec 2010
          • 417
          Re: KM Bizhub 222
          But..... did you check that they had reset before the F8 ? They can be stubborn to clear.
          Common for the solenoids in toner supply to stick and overtone as well.
          • 1stcavvet
            • Apr 2015
            • 231
            Re: KM Bizhub 222
            No, I never went back to check. If they didn't reset, can I reset them now? then rerun the f8??? I wouldn't want to run the f8 if the developer is over toned. that would really screw it up If they didn't reset, and the parts are new,is that ok to try to reset again now?
            • Woxner
              • Jul 2011
              • 850
              Re: KM Bizhub 222
              You can ck counters and run f8 again. If it's overtoned you can try and detone but dev is cheap. But make sure they 0 out. Turn machine off then on with main sw go back in and make sure they 0 out
              Sent from my XT1565 using Tapatalk
              • 1stcavvet
                • Apr 2015
                • 231
                Re: KM Bizhub 222
                Thanks I'll check all that ----- if that's not the issue and the counters were reset --- got any ideas on bias adjustments or anything else? Thanks again!!!
                • Woxner
                  • Jul 2011
                  • 850
                  Re: KM Bizhub 222
                  Since it's and old machine ck level history to see what toner ratio is. If it's high maybe the tone add drive assy. The solenoid foam goes bad and sticks. But you might be close to getting a 2557 code if it's too overtoned. Most of the time I have seen the hv cause light cq. But could be bad toner ESP if it's katun
                  • REGSIS
                    • May 2016
                    • 435
                    Re: KM Bizhub 222
                    I
                    Check the developer. If it is ok try to run 500 copies, this can solve the problem but be sure to use original toner.
                    • 1stcavvet
                      • Apr 2015
                      • 231
                      Re: KM Bizhub 222
                      how do you check toner density? what is a high level, over what kind of number?
