Bizhub c652
  • Syed Naseem
    • Jan 2017
    • 29
    Bizhub c652
    Hello everyone...
    I have facing print issue in my bizhub c652 last week.
    I changed All the Drum , Transfer Belt and heater unit but issue same.
    Mostly the issue comes when printing A3 duplex copy.
    One side of the page is fine and the second side of the half page is also fine but after the remaining half page print like that..
    I was print soo many times and observe that issus comes same after second side half page.
    I upload the issue image file plz if any body face this kind of broblem help me to resolve it..
    Thanks...
  • Woxner
    • Jul 2011
    • 850
    Re: Bizhub c652
    i see no file but since its second side check duplex transfer voltage and adjust as needed
    • allan
      RTFM!!
      • 5462
      Re: Bizhub c652
      Could be engine firmware.
      Whatever
      • Syed Naseem
        • Jan 2017
        • 29
        Re: Bizhub c652
        Are you sure engine firmware?
        I send image of result.
        • copier tech
          • 8170
          Re: Bizhub c652
          An weird issues it is best to update the firmware, we do this every visit.
          Have you fitted new image units & transfer unit or from another machine?
          • Syed Naseem
            • Jan 2017
            • 29
            Re: Bizhub c652
            Yes Sir i have install new drum units and tranfer belt as well but problem still same.
            You have engine firmware for this model ??
            • allan
              RTFM!!
              • 5462
              Re: Bizhub c652
              Your sample image is no good with out a reference original.
              Should the blue shade be there ?
              Whatever
              • Syed Naseem
                • Jan 2017
                • 29
                Re: Bizhub c652
                Just check the text image.
                Blue shade is not issue.
