BizHub 363 Movie Data
  • bkakour
    • Feb 2017
    • 8
    Hi to all,
    Recently I initialize the bizhub 363 and format the hard disk. Now missing the movie data, and would greatly appreciate it if someone can send me to install them.
    Thank you very much
  • Synthohol
    Certified Konica Expert
    • 5846
    Re: BizHub 363 Movie Data
    check your PMs
    • Froota
      Field service tech.
      • 129
      Hi,
      Normally the movie data is in the first mass firmware of the machine,
      You can download it with the firmware and install it seperately,
      • copier tech
        • 8169
        https://www.copierfirmware.co.uk/
        • Synthohol
          • 5846
          Originally posted by Froota
          Hi,
          the movie data is 60 meg by itself and FW is generally in the 90's.
          i havent seen movie data built into firmware, what version do you mean?
          • bkakour
            • Feb 2017
            • 8
            I want to thank you all for your immidiate and kind responses. The problem has been solved. Although now i am facing another problem with a tcm 3 usb card reader and it's connection with the bizhub 363. I will return with a new post for this new issue.
            Thanks again
            • Synthohol
              • 5846
              the old 363 only works USB2. it wont accept backwards compatibility. i have tried even usb3 flash drives and wont even register.
