Bizhub c652 - background with lines
  • HOEThumbTwiddler
    • Feb 2017
    • 4
    [CQ] Bizhub c652 - background with lines
    getting background on first 4-50 pages after start up okay for the rest of the day
    starts off dark gradually getting lighter
    if list output is done, background is not on page 1,3,5 but is on 2,4,6
    if printing demo page its on that
    replaced k drum and dev
    initialized stabilized and setup cq
    cleaned drum earths and connectors
    **see attached **
    attached was printed A4
    Thinking bias soo.. HV Board?
    ANY IDEAS WELCOME!
  • myster
    • Oct 2011
    • 79
    Re: Bizhub c652 - background with lines
    I can not see the fault
    The background comes out on the double side?
    The following issues are solved in this firmware.MFP firmware Ver.GCJ-D1
    5. A black line image was occurred on the leading edge paper for first copy/print. [PEBAU_13000297
    • HOEThumbTwiddler
      • Feb 2017
      • 4
      If doing double sided it comes out on page 2 (first page printed) page one would be okay
      see attachment and zoom in. it is hard to see but its hard to explain! like a grainy image.
      Struggled to pick up the background on the scan will take a photo hopefully you can see the fault then
      • HOEThumbTwiddler
        • Feb 2017
        • 4
        see attachment. hope this helps. away to try latest FW now!
        • Gift
          • Mar 2011
          • 2444
          It appears the border erase is OK so how does the background an lines look like in detail (magnification glas) - perhaps some sort of "digital" pattern? This might lead to bad memory/DIMM or laser issue.
          • myster
            • Oct 2011
            • 79
            Maybe transfer roller?
            Sometimes not well positioned
