Konica C364 Scan to email
  • mearmi
    • Oct 2010
    • 350
    Konica Minolta C364 doesn't scan to email
    Failed Job with "Server Connection Error"
    Please advise thanks
  • Synthohol
    Certified Konica Expert
    • 5846
    Re: Konica C364 Scan to email
    thats entirely too vague.
    what SMTP server/settings?
    if gmail or office365 you need special firmware as the non-e machines dont support the new security protocols.
    please elaborate.
    • mearmi
      • Oct 2010
      • 350
      please elaborate.
      Thanks a lot for your reply. Client is using 2 Copiers (C284e and C364). Both are using Gmail. C284e is scanning but 364 doesn't.
      If firmware? Can you please send me . Thanks and Regards,
      • Gift
        • Mar 2011
        • 2459
        This Office365 confuses me - I have a customer using a C451 and C454e - guess wich machine causing no trouble? It's the totally outdated C451 working flawless while the C454e does cause intermittent server connection issues. Tried latest FW and bulletins, fixed network speed and even swapping the network connection between both MFPs wich didn't change anything. I also don't understand why the error isn't reproduceable all the time - it's also not dependent on how much pages I need to scan.
        • rrrohan
          • Sep 2011
          • 1977
          Try setting gmail to "allow less secure apps"
          • Reed
            • Feb 2011
            • 258
            Is the firmware updated on the C364 to G00-72 ? It won't scan to email if it's not updated. I had the same problem with a C284. Once I updated the firmware it worked. Gmail updated their security settings and without the updated firmware the machine won't scan. There is a bulletin about the firmware and scanning issue.
            • copier tech
              • 8167
              He's using office365!
              • Reed
                • Feb 2011
                • 258
                I couldn't it to scan to email at all without updated firmware. It didn't matter which email it was authenticating through whether it be gmail, Office 365, yahoo, or the local internet provider. If the firmware isn't updated I suggest trying that first. It will drive you crazy.. trust me.
                • rrrohan
                  • Sep 2011
                  • 1977
                  when did he tell you that?
                  • Synthohol
                    • 5846
                    not the OP.
                    • mearmi
                      • Oct 2010
                      • 350
                      Yes we updated G00-72. It didn't work.
                      Can you please send me the firmware.
                      Thanks and Regards,
                      • Reed
                        • Feb 2011
                        • 258
                        there are also 2 smaller firmware patches you have install first.
                        • rrrohan
                          • Sep 2011
                          • 1977
                          can the OP please confirm what mail sever your using with details such as what port, encryption (if any), if authentication is req or off
                          if its gmail i use the not SSL server address and enable "allow less ecure apps"
                          depending on the mail server using your ISP mail server might be a option
                          • Konicatech
                            • Feb 2016
                            • 131
                            As has already been stated, you need to update the firmware first (firmware effectively makes it an 'e' machine).
                            Once done, you need to make the following settings:
                            1. Login to your GMAIL account and turn on 'Less secure apps' - If this is not turned on, then it simply will not work!
                            2. Set mail server address to smtp.gmail.com, choose start TLS, and set to port 465
                            3. Turn on authentication, and input your @gmail.com address as the username and put your password in.
                            You also need to have the device email address set etc to match the gmail account.
