faint coloured
  • spidar
    • Feb 2017
    • 6
    faint coloured
    Konica Minolta c452
    I have this faint band in 4 colours test.
  • Synthohol
    Certified Konica Expert
    • 5824
    Re: faint coloured
    there is a setting for adjusting transfer voltage of trail edge.
      • 23008
      Re: faint coloured
      Is you faint area in which direction on which size paper? =^..^=
      • Synthohol
        • 5824
        Re: faint coloured
        good question!
        i just assumed it was the trailing edge from memory of that image.
        • spidar
          • Feb 2017
          • 6
          Re: faint coloured
          A4 & bigger than A4
          • Synthohol
            • 5824
            Re: faint coloured
            the stripe, is it in the feed or cross direction was the question.
            • myster
              • Oct 2011
              • 79
              Re: faint coloured
              It may be dirt in the optics of the laser, it has to be disassembled and cleaned well
                • 14725
                Re: faint coloured
                If it is on all colours, I would suspect the transfer belt or roller. Also, use the magic wand on the inside of the door to clean the printheads.
                  • 23008
                  Re: faint coloured
                  I can wait for the details. =^..^=
                  • M3HR4N
                    • Jun 2015
                    • 34
                    Re: faint coloured
                    I've got the same problem, change anything you name it but no luck.
                    • insigniawales
                      • 29
                      Re: faint coloured
                      Could be the media type. If the weight of the paper is greater thatn 80gsm it could cause banding as described. You can adjust the 2nd transfer voltages in service mode
                      Sent from my SM-G903F using Tapatalk
