Image Quality Question
  • Mitch Barron
    • Mar 2013
    • 180
    Greetings all.
    I suppose this week is just one of those weeks where everything just doesn't work for me. I have a Ineo+224 (Bizhub c224) at a customer that is making ugly lines on the printed pages. I will attach an example so you can see what I am talking about. Interestingly enough I know where the Problem stems from (ITB) I have since replaced the belt and Transfer roller, but the Problem persists, just not as bad. Just thought I would ask if anyone else has had a similar Situation in the past before i start tearing the machine apart to find the cuplrit. I sadly do not have an example of the Problem after changing the belt, but the Problem is still in the same position (running through the "W" in "witzige") it is just not as pronounce as the examples in the attached PDFs. Any info would be greatly appreciated. Thanks!
    PS- in the attachment, the Image on the left was printed in landscape and the one on the right was printed in Portrait. There are more than one Position where These lines are visible, but after changing the belt the other positions were solved.
    müllerkarton image quality.pdf
    All the best!
    Mitch
  • Synthohol
    Certified Konica Expert
    • 5839
    Re: Image Quality Question
    Clean the printheads with the wand in the door and give the corona cleaners a dozen pulls on the white levers
    If you print the cmyk gradation patterns before and after you will see what color had the shmutz
      • 23008
      Try this:
        • 14760
        Looks like the black drum has expired.
        • Max
          • Oct 2011
          • 559
          Corona, laser glass and dev units gap blade contamination. Clean/replace where needed
          • Mitch Barron
            • Mar 2013
            • 180
            Thanks for all the Feedback everyone. I am going to try to get an appointment there this afternoon and see if I get the kinks ironed out of this machine. Will Report back with my results!
            Thanks again!
            M
