bizhub 421 poor printing output
  • landpromise
    • Mar 2015
    • 5
    gday guys
    our bizhub 421 printer is printing documents and missing a section of ink about a quarter down the page
    so on a particular page youll see a white line horizontally across an A4 sheet about a centimeter thick
    ive sprayed the inside of the printer out with circuit board spray and tried to get the crap off the rollers, it hasnt helped
    not sure what else to do, any ideas?
  • mo0651
    • 1054
    Re: bizhub 421 poor printing output
    Scan in and post an image, and tell us feed direction. Always helpful. Could be a Dev unit.
    • Woxner
      • Jul 2011
      • 854
      could be dirty t corona, charge corona or blank spot in dev unit. transfer corona tend to blank out on these esp when dirty. they wont code until they short complety for 5 times in a row.
      • landpromise
        • Mar 2015
        • 5
        thanks guys
        we actually have another clone of this 421 printer in the shed
        i could swap bits off it, which is what i did with the big fusing unit when the faults started occurring
        i really dont know what your talking about with components, but if could lead me to a few links that would be brilliant
        its the weekend im only here at work for a half hour but by tuesday can reply thoroughly
        i will also get a photo of the output asap
        • landpromise
          • Mar 2015
          • 5
          so heres the issue any ideas why this is happening?.....
          (inkless area on right side)
          the developer unit does look to have a ink dust trails on the roller where this ink is missing
          do i have to take the fusing unit out to get the dev unit out??
          • darry1322
            • Oct 2010
            • 817
            It may be something blocking the laser from hitting the drum in that area.
            • CraigW
              • Dec 2010
              • 417
              ^^^ Yes, check the cleaners status behind front door. Smallest, lowest knob.
                • 23010
                Yes, it looks like a dirty laser slit glass to me. =^..^=
                • myster
                  • Oct 2011
                  • 79
                  cleanner of the main charge corona ??
                  • landpromise
                    • Mar 2015
                    • 5
                    well oh my god, i cleaned the pins you mentioned from behind the front small door
                    and cleaned the slit glass and its printing fine now
                    unbelievable a 20 second job
                    which do we believe did it, the slit or cleaning the pins?
                    how do i clean the coroner champ
                      • 15063
                      If the charge corona was being blocked he would have been getting black lines, not void lines.
