Konica minolta Bizhub C 252
  • Nazakat
    • 67
    Hi to all
    Can anybody tell me how to reset transfer unit in Konica Minolta C 252?
    Thanks in Advance
  • dogsbody
    • Jun 2007
    • 289
    replace the fuse. it is a 80mA glass fuse but i have used 50, 80 and 100mA.
    The force will be with you always.
    • Nazakat
      • 67
      Bizhub C 252
      Dear Friend,
      I have worked alot on toshiba but on Bizhub i am new.Please guide me where can i find the Fuse? i took out the transfer unit but couldent find the fuse.
      • dogsbody
        • Jun 2007
        • 289
        imagine the transfer belt in the machine, it should be on the right at the front. there is a small cover that comes off and it is under there.
        • ni311
          • May 2008
          • 658
          http://www.copytechnet.com/forums/ko...sfer-unit.html
          Konica Minolta Error Codes - Explanations and Solutions
          • Nazakat
            • 67
            C-252 Transfer Belt
            Dear Friend,
            I have replaced the fuse of Transfer belt but after that it start giving Code C-2451 and stuck.I tried to place fuse 50ma,80ma and 100ma but to no avail.What else i can do to reset it.
            • ni311
              • May 2008
              • 658
              Did you try to reset the code?
              Start from main power with the utility button holded down until trouble reset pops up on the display, touch the button, turn it off and then on.
              • Nazakat
                • 67
                Friend,
                I did that but when copier reaches to Stablizing Images it gives that Code Again.
                • DadO
                  • Dec 2007
                  • 404
                  Recheck the ITB. Check the how ITB lays on its position. This works 100% so it looks like u didnt place fuse correctly and check metal connector of ITB and the machine
                  • sta
                    details
                    please talk to me what replace fuse.
                    • 1to2
                      Originally posted by Nazakat
                      Hi to all
                      Thanks in Advance
                      You need to replace a special fuse on the front side handle of the belt unit, behind a little black cover.
