I have worked alot on toshiba but on Bizhub i am new.Please guide me where can i find the Fuse? i took out the transfer unit but couldent find the fuse.
I have replaced the fuse of Transfer belt but after that it start giving Code C-2451 and stuck.I tried to place fuse 50ma,80ma and 100ma but to no avail.What else i can do to reset it.
Did you try to reset the code?
Start from main power with the utility button holded down until trouble reset pops up on the display, touch the button, turn it off and then on.
Recheck the ITB. Check the how ITB lays on its position. This works 100% so it looks like u didnt place fuse correctly and check metal connector of ITB and the machine
