BIZ HUB 280
  • antone
    • Oct 2014
    • 344
    BIZ HUB 280
    Error message CE002....only with network cable in port.Cable good..network good...With out cable in port copier runs fine!!!Any tricks..?
    Sent from my SM-N920V using Tapatalk
  • Synthohol
    Certified Konica Expert
    • 5846
    Re: BIZ HUB 280
    ping the IP with it unplugged, see if there is a conflict?
      • 23009
      Re: BIZ HUB 280
      What happens if you crossover to your laptop? =^..^=
      • antone
        • Oct 2014
        • 344
        Re: BIZ HUB 280
        IT...chk this out...hooked up computer ect....not the .network
          • 23009
          Re: BIZ HUB 280
          Does this mean that it communicated directly to the laptop, or did not? =^..^=
          • antone
            • Oct 2014
            • 344
            Re: BIZ HUB 280
            Yes it did....
              • 23009
              Re: BIZ HUB 280
              If it communicated with the laptop then the problem is on the network. Did you check for a dupe like Synthohol suggests? =^..^=
              • antone
                • Oct 2014
                • 344
                Re: BIZ HUB 280
                Cross over cable...directy
                  • 23009
                  Re: BIZ HUB 280
                  I do not understand how this answers the question.
                  Did you check for a duplicate IP address on the network? Unplug the MFP from the network > connect your laptop to the network cable > ping the IP address > does anything answer back? > if yes, something else is using the same IP address.
                  If this is the case you can use a utility like Network Scanner to identify the MAC address and consequently the maker of the network device. If you have a lot of network devices on the network it still can be difficult to find the offending device. It's generally easier to change the IP address to an open/unused address at the MFP and at the print driver.
                  • antone
                    • Oct 2014
                    • 344
                    Re: BIZ HUB 280
                    I did all those things...ordered a hard drive MFP board..some thing up with the copier!
                      • 23009
                      Re: BIZ HUB 280
                      I don't think we're speaking the same language. That's fine. It seems like you have a plan. =^..^=
                      • antone
                        • Oct 2014
                        • 344
                        Re: BIZ HUB 280
                        Thanks ...trying a hard drive
                        • allan
                          RTFM!!
                          • 5462
                          Re: BIZ HUB 280
                          May the force be with you.
                          Whatever
                          • k2@bpos.ca
                            Re: BIZ HUB 280
                            I had a similar issue with a c353. Ended up being the hard drive. Replaced and all was good.
                            Sent from my STV100-3 using Tapatalk
                            • antone
                              • Oct 2014
                              • 344
                              Re: BIZ HUB 280
                              I will let you know
