BizHub C220 Firmware - How to Install?!
  • LODAN31
    • Aug 2021
    • 2
    Re: BizHub C220 Firmware - How to Install?!
    Originally posted by copyman
    The USB port on right side by control panel is for end user convenience to insert flash drive. This port can also be used to load "special" F/W but only movie, voice & OCR data. ALL other F/W has to be installed with port behind small cover. The reason there is a cover over port is because it is only for firmware.
    Let me know if you need Konica Minolta F/W for FREE. I will only provide it to "long term" members of this site. I will not reply to anyone else or to anyone that sells F/W !!!
    hello, I am looking for the firmware for bizhub C220, can you provide it to me? thank you very much
      • 8195
      Happy to help with this.
      Please contact us at the links below.
