BizHub C220 Firmware - How to Install?!
  • TheAlikA
    • Mar 2017
    • 9
    I found firmware for my "Olivetti d-Color MF220" which is the same thing as the Konica Minolta c220 for everyone else.
    Index de ./Machine Couleur/Copieur Couleur/D-Color MF220-280-360/Firmware/ << this is the Link
    The latest firmware is the G00-C06 but How do I install it?
    Here is what I have tried so far:
    Step 1: Download file: A0ED0Y0-F000-G00-C6.exe
    Step 2: Format 16GB USB2 Flash drive to FAT32
    Step 3: Extract files from the .exe
    Step 4: Copy the extracted files to USB
    Step 5: Place the USB a the back of the printer and switch it on.
    Step 6: .... nothing happens
    Please Help.
    I tried extracting files and placing the .exe file in the root directory, I also tried different firmware...
  • copyman
    Owner / Technician
    • Sep 2005
    • 4718
    Re: BizHub C220 Firmware - How to Install?!
    Use a flash drive 4GB or less. Copy and paste only the .tar file to the flash drive. Use service port behind small cover on right rear. Install with "main switch" off, then turn on. May take several mins for firmware screen to appear.
    • copier tech
      • 8169
      Yes assuming you have the correct firmware you simply put the .tar file onto a USB drive no larger than 2GB.
      Also the version you have is outdated, GDH-D1 is the latest available.
      C220 Series GDH-D1 ReadMe.pdf
      • korthr5
        • Feb 2016
        • 39
        Please Help.
        Hello
        On Step 5 you can not put in any USB on back.. Only on the hidden USB.
        • TheAlikA
          • Mar 2017
          • 9
          [ATTACH]35961[/ATTACH]
          • copyman
            Owner / Technician
            • Sep 2005
            • 4718
            What do you mean the firmware cost money? Is someone trying to sell you Firmware on this website? No one should be charging for F/W or manuals!
            • TheAlikA
              • Mar 2017
              • 9
              • TheAlikA
                • Mar 2017
                • 9
                Firstly, that is exactly what I was doing, and also what I mentioned in my post, but thanks for confirming.
                Secondly, I disagree... there is a USB extension cable that runs from the back service port to the front user accessible port, that's the only difference. How that will affect data transfer I can not see possible. (I'm including a screenshot just to be clear)
                • avecosat
                  • Jun 2012
                  • 305
                  The only valid usb is the one that is covered
                  • summercloud
                    [ATTACH=CONFIG]36037[/ATTACH]
                    Just registered to this site to write you a message.
                    Yesterday was trying to upgrade same firmware and had same issues.
                    There is a third USB port in the back behind the screw:
                    You have to insert the flash drive to that port when the main switch is off. Then turn the machine on and firmware upgrade will boot up.
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4718
                      The USB port on right side by control panel is for end user convenience to insert flash drive. This port can also be used to load "special" F/W but only movie, voice & OCR data. ALL other F/W has to be installed with port behind small cover. The reason there is a cover over port is because it is only for firmware.
                      Let me know if you need Konica Minolta F/W for FREE. I will only provide it to "long term" members of this site. I will not reply to anyone else or to anyone that sells F/W !!!
                      • TheAlikA
                        • Mar 2017
                        • 9
                        There is a third USB port in the back, behind the screw:
                        YES!!!
                        That worked!!
                        After the firmware installs, do you simply unplug the printer, or must you do something to shut down saftley?
                        • summercloud
                          Shut down by turning MAIN SWITCH off:
                          The best manual I found: https://www.manualslib.com/manual/43...page=33#manual
                          • hussainsalget
                            • Sep 2019
                            • 2
                            it doesn't work
                            Please Help.
                            • emujo2
                              • Mar 2017
                              • 1579
                              You are mistaken, he said it worked..If you are referring to your own machine try starting your own thread. E
