Document Feeder Jamming Help!!
  • pern2808
    • Sep 2015
    • 17
    [Jamming] Document Feeder Jamming Help!!
    Hi I have a customer with a Develop / Konica Minolta 224e with a DF-64 which when scanning/copying using the DF it is constantly jamming/stopping about 1cm before fully exiting the paper. This is regardless of whether scanning portrait or landscape, roughly stops the same distance on exit. Have replaced sensors and replaced rollers/pick up etc. The DF will be fine for about a day and then it happens again. Its driving me nuts. Any help would be appreciated.
  • service_man
    • Jul 2012
    • 59
    Re: Document Feeder Jamming Help!!
    Did you try to initialize ADF with test chart? Stop position and white read?
    • pern2808
      • Sep 2015
      • 17
      I haven't as of yet. But I am going back there this afternoon and will do that and let you know. Thank you.
        • 22999
        Jam code?
        • pern2808
          • Sep 2015
          • 17
          Jam code?
          Hi blackcat, always 25 jam code. After replacing the 200,000 maintenance set of pick up / separation rollers( 2nd time now) and doing an auto stop with the test chart that service_man suggested the issue has for now disappeared. (Disappeared after doing stop with test chart) then replaced rollers. FIngers crossed that will sort and I wont see that DF for a little while to come!! Thanks to all.
