DF621 on Bizhub 223, 283, 363, 423 jam code 66-02
    • 23010
    #16
    Re: DF621 on Bizhub 223, 283, 363, 423 jam code 66-02
    That sounds like success, at least in the short term. Please keep us posted how it progresses. =^..^=
    • CraigW
      • Dec 2010
      • 417
      #17
      I think this to be a model feeder that has a modified paper present actuator available that can accept a magnet to prevent this from occurring.
      • Don N.
        • Nov 2011
        • 409
        #18
        CraigW: I haven't seen a part # or any mention of that. Again, if it's warped up high enough, paper can get under the flag and cause other issues. Best to get the lid flattened back down to less than 25mm. Most working units in the field are about 23~24 mm. See pic of measurement.
        • CraigW
          • Dec 2010
          • 417
          #19
          Actuator = A3CFPP4VOO
          Magnet = A3CFPP1700
          The 621 IIRC does NOT have these from factory though.
          • Don N.
            • Nov 2011
            • 409
            #20
            Magnet = A3CFPP1700
            CraigW - My Nov. 2014 parts manual does not have this part listed. Is this definitely a DF621 part? Not sure what IIRC means.
            THANKS!
            • CraigW
              • Dec 2010
              • 417
              #21
              This parts change is only 1-1.5 years old.
              KMBS still has the same 2014 version parts manual on their site.
              IIRC= If I Remember Correctly.
              • Don N.
                • Nov 2011
                • 409
                #22
                Magnet = A3CFPP1700
                I tried to put the actuator with magnet A3CFPP4VOO from a 4/e series (DF624 & DF701) onto a DF621 (BH223 series) and it won't work. The top end is too big, preventing it from swinging completely down.
                Still some value in gluing the magnet only A3CFPP1700 onto the old style DF621 actuator as long as the lid is not warped above 25+ mm.
                • Don N.
                  • Nov 2011
                  • 409
                  #23
                  Magnet = A3CFPP1700
                  Just to close out this old post, that new style lever & magnet for the 4e series DF629 & DF701 is working well on these older DF621 on 223 series. We just had to cut a couple of mm off the top of the new 4e style lever... Nipping it just at the top of the round circle stamped into the top with a number in it.
                  THANKS CRAIGW!
