Konica 361 c2403 code
  • DOE
    • Mar 2010
    • 258
    Have a black and white Konica 361 that when the customer makes long runs every three hundred copies or so a C2403 code comes up. Customer able to turn machine off and on and run another 300 period I have vacuumed out the sensors in the back and the problem continues I also installed a genuine Konica toner and made sure the ring was lined up in the 1 o'clock position to fit in that Groove in the bottle. The Next Step I assume is to replace the photo sensor I just wanted to make sure there wasn't something I might be overlooking as I hear it is quite a job to replace that photo sensor. Any idea would be appreciated
  • CraigW
    • Dec 2010
    • 417
    Re: Konica 361 c2403 code
    Sensor may just be dirty.
    I have a length of conduit that allows one to reach back to sensors and blast with air.
    Also, on the 1s with the finisher off there is a plate/cover that can be removed for access to sensors.
    I'm south of you in Lancaster.....A town.
    • DOE
      • Mar 2010
      • 258
      I have been there twice and clean the sensors and neither time seemed to make a difference. Doesn't make sense that it works fine 300 times and then a codes and you turned off and on and can make another 300
      • PCC.TONER
        • Mar 2017
        • 13
        Reason maybe is one of followings:
        Toner bottle motor (M10)
        Toner bottle position sensor (PS28)
        Printer control board (PRCB)
        Linda
        • 907tec
          • 434
          I hate the 360/361 series with a passion. c2403 / toner bottle related codes on this series are possibly my most dreaded task in the biz. Not that it is difficult: I just have a (potentially) irrational hatred for this series.
          My basic advice: remove the entire toner bottle and hopper mechanism. Clean and vacuum everything, thoroughly. Reassemble. Make sure to test the machine by running the load-checks repeatedly.
          Reference material:
          C-2403_Countermeasure.pdf
          TSU.pdf
          • Woxner
            • Jul 2011
            • 845
            replace the sub hopper unit and it will go away. its what turn the bottle.
            • DOE
              • Mar 2010
              • 258
              The code seems to be coming up more often now. Every two or three hundred copies you have to turn off and then back on. Does anybody have a port number for the sub toner Hopper unit. I do not have service or parts manuals for anything unfortunately. Thank you
              • Woxner
                • Jul 2011
                • 845
                50GA-3222 you may also want to make surte it has the last firmware they came out with. it change a few thing for toner sensor . also mike want to replace the ring and cleeaning felts . i have seen the ring get hard to turn from wear
