konica minolta c600 bad black toner
  • rofield67
    • May 2014
    • 15
    [CQ] konica minolta c600 bad black toner
    I have found some bad black toner TN610K for the koinica Minolta c6500. I have been fighting a problem with spoty half tones, black only on a few of the machines I service. . I did a developer change and the copies looked good for a short time before the spots came back. I eventually had to vacuum hopper replace black toner bottle with one with a different skew#. when I remove the toner bottle I find they all have the skew# 680924SA. Sounds crazy but I have seen this problem a several times in the last few weeks.
  • rofield67
    • May 2014
    • 15
    Re: konica minolta c6500 bad black toner TN610k
    My bad, machine I am talking about is C6500, TN610k.
    • Woxner
      • Jul 2011
      • 842
      Re: konica minolta c600 bad black toner
      are you using oem or generic? i have not seen any bad oem toner.
      • rofield67
        • May 2014
        • 15
        always OEM. I thought it was a coincidence but I found problem on several machines only with the toner with skew # I listed. Just a heads up to save you some time troubleshooting if you see this problem. A few of my customers didn't notice it because they run publications with limited graphics, but a few run bleeds with lots of gradations, they noticed it for sure. If I run into again I will post a pic. looks like a leopard skin pattern in half tones, solids look great cant notice it.
